Auto-Talk strives hard to provide our users with up to date information on Toyota Supra. When trying to swap your automatic transmission to a 6-speed manual, keep in mind that you will need to verify the parts list with your dealer. You still need the transmission, clutch, flywheel and other main parts. We have provided a brief outline on what parts you need. Prices are for references only and cannot be guaranteed.
90363-12002-77 pilot bearing list 8.76 cost 6.17
90910-02115 flywheel bolts list 9.40 cost 6.61 ea x 8
90119-08079 pressure plate bolts list .43 cost .30 ea x 8
90903-63001 t/o bearing list 63.42 cost 44.61
31231-14050 t/o bearing hub list 30.21 cost 21.25
96152-00500 snap ring list 2.57 cost 1.81
90560-79001 spacer list 2.26 cost 1.59
90206-12006 wave washer list 1.51 cost 1.06
90520-75001 snap ring list 2.89 cost 2.04
90560-50001 spacer list 5.69 cost 4.00
31264-14060 spring washer list 2.89 cost 2.04
Slave cylinder 31470-14060 list 59.65 cost 41.96
Master cylinder 31410-14310 list 97.04 cost 68.26
Clutch pedal assembly 55107-14140 bracket list 67.85 cost 47.72 31311-14120 pedal list 41.01 cost 28.85
differential 41110-14780 list 2308.42 cost 1623.74
drive shaft 37100-14810 list 672.79 cost 473.24
6spd tranny mount 12371-46110 list 67.51 cost 47.48
