Toyota Motor Sales announced that it will conduct a voluntary Safety Recall involving approximately 740,000 – 2005 through 2006 Avalon, 2004 through 2006 Highlander (non Hybrid) and Lexus RX330, and 2006 Lexus GS300, IS250, and IS350 vehicles sold in the United States to address the possibility that a small amount of the brake fluid could slowly leak from the brake master cylinder, resulting in illumination of the brake warning lamp.
This action follows an announcement made by Toyota Motor Corporation in Japan on October 21, 2010 (Japan).
The Toyota genuine brake fluid used during vehicle assembly for vehicles sold in the United States contains polymers. The polymers act as lubricants for certain brake system components. If during vehicle maintenance, brake fluid is used that does not contain such polymers or only small amounts, a part of the internal rubber seal (brake master cylinder cup) located at the end of the brake master cylinder piston may become dry and may curl during movement of the piston. If this occurs, a small amount of the brake fluid could slowly leak from the brake master cylinder into the brake booster, resulting in illumination of the brake warning lamp.
If the brake warning lamp has illuminated and the vehicle continues to be operated without refilling the master cylinder brake fluid reservoir, the driver will begin to notice a spongy or soft brake pedal feel and braking performance may gradually decline.
Owners of the involved vehicles will be notified by first class mail beginning in early November 2010. Toyota and Lexus dealers will replace the brake master cylinder cup with a newly designed one at no charge to the vehicle owners.
Detailed information and answers to questions are available to customers at www.toyota.com/recall or www.lexus.com/recall and the Toyota Customer Experience Center at 1-800-331-4331 or Lexus Customer Satisfaction at 1-800-25 LEXUS or 1-800-255-3987.
