Code | Description |
B1200 | Climate Control Pushbutton Circuit Failure |
B1201 | Fuel Sender Circuit Failure |
B1202 | Fuel Sender Circuit Open |
B1203 | Fuel Sender Circuit Short To Battery |
B1204 | Fuel Sender Circuit Short To Ground |
B1205 | EIC Switch-1 Assembly Circuit Failure |
B1206 | EIC Switch-1 Assembly Circuit Open |
B1207 | EIC Switch-1 Assembly Circuit Short To Battery |
B1208 | EIC Switch-1 Assembly Circuit Short To Ground |
B1209 | EIC Switch-2 Assembly Circuit Failure |
B1210 | EIC Switch-2 Assembly Circuit Open |
B1211 | EIC Switch-2 Assembly Circuit Short To Battery |
B1212 | EIC Switch-2 Assembly Circuit Short To Ground |
B1213 | Anti-Theft Number of Programmed Keys Is Below Minimum |
B1214 | Running Board Lamp Circuit Failure |
B1215 | Running Board Lamp Circuit Short to Battery |
B1216 | Emergency & Road Side Assistance Switch Circuit Short to Ground |
B1217 | Horn Relay Coil Circuit Failure |
B1218 | Horn Relay Coil Circuit Short to Vbatt |
B1219 | Fuel Tank Pressure Sensor Circuit Failure |
B1220 | Fuel Tank Pressure Sensor Circuit Open |
B1222 | Fuel Temperature Sensor #1 Circuit Failure |
B1223 | Fuel Temperature Sensor #1 Circuit Open |
B1224 | Fuel Temperature Sensor #1 Circuit Short to Battery |
B1225 | Fuel Temperature Sensor #1 Circuit Short to Ground |
B1226 | Fuel Temperature Sensor #2 Circuit Failure |
B1227 | Fuel Temperature Sensor #2 Circuit Open |
B1228 | Fuel Temperature Sensor #2 Circuit Short to Battery |
B1229 | Fuel Temperature Sensor #2 Circuit Short to Ground |
B1231 | Longitudinal Acceleration Threshold Exceeded |
B1232 | See Manufacturer |
B1233 | Glass Break Sensor Failure |
B1234 | Mirror Switch Invalid Code |
B1235 | Window Feedback Failure |
B1236 | Window Feedback Loss of Signal |
B1237 | Window Feedback Out of Range |
B1238 | Over Temperature Fault |
B1239 | Air Flow Blend Door Driver Circuit Failure |
B1240 | Wiper Washer Rear Pump Relay Circuit Failure |
{mospagebreak}
B1241 | Wiper Washer Rear Pump Relay Circuit Short to Battery |
B1242 | Air Flow Recirculation Door Driver Circuit Failure |
B1243 | Express Window Down Switch Circuit Short to Battery |
B1244 | Wiper Rear Motor Run Relay Circuit Failure |
B1245 | Wiper Rear Motor Run Relay Circuit Short to Battery |
B1246 | Dim Panel Potentiometer Switch Circuit Failure |
B1247 | Panel Dim Switch Circuit Open |
B1248 | Passenger's Seatback Autoglide Rearward Switch Circuit Short to Ground |
B1249 | Blend Door Failure |
B1250 | Air Temperature Internal Sensor Circuit Failure |
B1251 | Air Temperature Internal Sensor Circuit Open |
B1252 | Air Temperature Internal Sensor Circuit Short To Battery |
B1253 | Air Temperature Internal Sensor Circuit Short To Ground |
B1254 | Air Temperature External Sensor Circuit Failure |
B1255 | Air Temperature External Sensor Circuit Open |
B1256 | Air Temperature External Sensor Circuit Short To Battery |
B1257 | Air Temperature External Sensor Circuit Short To Ground |
B1258 | Solar Radiation Sensor Circuit Failure |
B1259 | Solar Radiation Sensor Circuit Open |
B1260 | Solar Radiation Sensor Circuit Short To Battery |
B1261 | Solar Radiation Sensor Circuit Short To Ground |
B1262 | Servo Motor Defrost Circuit Failure |
B1263 | Servo Motor Vent Circuit Failure |
B1264 | Servo Motor Foot Circuit Failure |
B1265 | Servo Motor Coolair Bypass Circuit Failure |
B1266 | Servo Motor Airintake Left Circuit Failure |
B1267 | Servo Motor Airintake Right Circuit Failure |
B1268 | Servo Motor Potentiometer Defrost Circuit Failure |
B1269 | Servo Motor Potentiometer Defrost Circuit Open |
B1270 | Servo Motor Potentiometer Defrost Circuit Short To Battery |
B1271 | Servo Motor Potentiometer Defrost Circuit Short To Ground |
B1272 | Servo Motor Potentiometer Vent Circuit Failure |
B1273 | Servo Motor Potentiometer Vent Circuit Open |
B1274 | Servo Motor Potentiometer Vent Circuit Short To Battery |
B1275 | Servo Motor Potentiometer Vent Circuit Short To Ground |
B1276 | Servo Motor Potentiometer Foot Circuit Failure |
B1277 | Servo Motor Potentiometer Foot Circuit Open |
B1278 | Servo Motor Potentiometer Foot Circuit Short To Battery |
B1279 | Servo Motor Potentiometer Foot Circuit Short To Ground |
B1280 | Servo Motor Potentiometer Coolair Circuit Failure |
{mospagebreak}
B1281 | Servo Motor Potentiometer Coolair Circuit Open |
B1282 | Servo Motor Potentiometer Coolair Circuit Short To Battery |
B1283 | Servo Motor Potentiometer Coolair Circuit Short To Ground |
B1284 | Servo Motor Potentiometer Airintake Left Circuit Failure |
B1285 | Servo Motor Potentiometer Airintake Left Circuit Open |
B1286 | Servo Motor Potentiometer Airintake Left Circuit Short To Battery |
B1287 | Servo Motor Potentiometer Airintake Left Circuit Short To Ground |
B1288 | Servo Motor Potentiometer Airintake Right Circuit Failure |
B1289 | Servo Motor Potentiometer Airintake Right Circuit Open |
B1290 | Servo Motor Potentiometer Airintake Right Circuit Short To Battery |
B1291 | Servo Motor Potentiometer Airintake Right Circuit Short To Ground |
B1292 | Battery Power Relay Circuit Failure |
B1293 | Battery Power Relay Circuit Open |
B1294 | Battery Power Relay Circuit Short To Battery |
B1295 | Battery Power Relay Circuit Short To Ground |
B1296 | Power Supply Sensor Circuit Failure |
B1297 | Power Supply Sensor Circuit Open |
B1298 | Power Supply Sensor Circuit Short To Battery |
B1299 | Power Supply Sensor Circuit Short To Ground |
B1300 | Power Door Lock Circuit Failure |
B1301 | Power Door Lock Circuit Open |
B1302 | Accessory Delay Relay Coil Circuit Failure |
B1303 | Accessory Delay Relay Coil Circuit Open |
B1304 | Accessory Delay Relay Coil Circuit Short To Battery |
B1305 | Accessory Delay Relay Coil Circuit Short To Ground |
B1306 | Oil Level Switch Circuit Open |
B1307 | Oil Level Switch Circuit Short To Battery |
B1308 | Oil Level Switch Circuit Short To Ground |
B1309 | Power Door Lock Circuit Short To Ground |
B1310 | Power Door Unlock Circuit Failure |
B1311 | Power Door Unlock Circuit Open |
B1312 | Lamp Headlamp Input Circuit Short To Battery |
B1313 | Battery Saver Relay Coil Circuit Failure |
B1314 | Battery Saver Relay Coil Circuit Open |
B1315 | Battery Saver Relay Coil Circuit Short To Battery |
B1316 | Battery Saver Relay Coil Circuit Short To Ground |
B1317 | Battery Voltage High |
B1318 | Battery Voltage Low |
B1319 | Driver Door Ajar Circuit Failure |
B1320 | Driver Door Ajar Circuit Open |
{mospagebreak}
B1321 | Driver Door Ajar Circuit Short To Battery |
B1322 | Driver Door Ajar Circuit Short To Ground |
B1323 | Door Ajar Lamp Circuit Failure |
B1324 | Door Ajar Lamp Circuit Open |
B1325 | Door Ajar Lamp Circuit Short To Battery |
B1326 | Door Ajar Lamp Circuit Short To Ground |
B1327 | Passenger Door Ajar Circuit Failure |
B1328 | Passenger Door Ajar Circuit Open |
B1329 | Passenger Door Ajar Circuit Short To Battery |
B1330 | Passenger Door Ajar Circuit Short To Ground |
B1331 | Decklid Ajar Rear Door Circuit Failure |
B1332 | Decklid Ajar Rear Door Circuit Open |
B1333 | Decklid Ajar Rear Door Circuit Short To Battery |
B1334 | Decklid Ajar Rear Door Circuit Short To Ground |
B1335 | Door Ajar RR Circuit Failure |
B1336 | Door Ajar RR Circuit Open |
B1337 | Door Ajar RR Circuit Short To Battery |
B1338 | Door Ajar RR Circuit Short To Ground |
B1339 | Chime Input Request Circuit Short To Battery |
B1340 | Chime Input Request Circuit Short To Ground |
B1341 | Power Door Unlock Circuit Short To Ground |
B1342 | ECU Is Defective |
B1343 | Heated Backlite Input Circuit Failure |
B1344 | Heated Backlite Input Circuit Open |
B1345 | Heated Backlite Input Circuit Short To Ground |
B1346 | Heated Backlite Input Circuit Short To Battery |
B1347 | Heated Backlite Relay Circuit Failure |
B1348 | Heated Backlite Relay Circuit Open |
B1349 | Heated Backlite Relay Short To Battery |
B1350 | Heated Backlite Relay Short To Ground |
B1351 | Ignition Key-In Circuit Short To Battery |
B1352 | Ignition Key-In Circuit Failure |
B1353 | Ignition Key-In Circuit Open |
B1354 | Ignition Key-In Circuit Short To Ground |
B1355 | Ignition Run Circuit Failure |
B1356 | Ignition Run Circuit Open |
B1357 | Ignition Run Circuit Short To Battery |
B1358 | Ignition Run Circuit Short To Ground |
B1359 | Ignition Run/Acc Circuit Failure |
B1360 | Ignition Run/Acc Circuit Open |
{mospagebreak}
B1361 | Ignition Run/Acc Circuit Short To Battery |
B1362 | Ignition Run/Acc Circuit Short To Ground |
B1363 | Ignition Start Circuit Failure |
B1364 | Ignition Start Circuit Open |
B1365 | Ignition Start Circuit Short To Battery |
B1366 | Ignition Start Circuit Short To Ground |
B1367 | Ignition Tach Circuit Failure |
B1368 | Ignition Tach Circuit Open |
B1369 | Ignition Tach Circuit Short To Battery |
B1370 | Ignition Tach Circuit Short To Ground |
B1371 | Illuminated Entry Relay Circuit Failure |
B1372 | Illuminated Entry Relay Circuit Open |
B1373 | Illuminated Entry Relay Short To Battery |
B1374 | Illuminated Entry Relay Short To Ground |
B1375 | Oil Change Lamp Circuit Open |
B1376 | Oil Change Lamp Circuit Short To Battery |
B1377 | Oil Change Lamp Circuit Failure |
B1378 | Oil Change Lamp Circuit Short To Ground |
B1379 | Oil Change Reset Button Circuit Short To Ground |
B1380 | Oil Change Reset Button Circuit Failure |
B1381 | Oil Change Reset Button Circuit Open |
B1382 | Oil Change Reset Button Circuit Short To Battery |
B1383 | Oil Level Lamp Circuit Short To Battery |
B1384 | Oil Level Lamp Circuit Failure |
B1385 | Oil Level Lamp Circuit Open |
B1386 | Oil Level Lamp Circuit Short To Ground |
B1387 | Oil Temperature Sensor Circuit Open |
B1388 | Oil Temperature Sensor Circuit Short To Battery |
B1389 | Oil Temperature Sensor Circuit Failure |
B1390 | Oil Temperature Sensor Circuit Short To Ground |
B1391 | Oil Level Switch Circuit Failure |
B1392 | Power Door Memory Lock Relay Circuit Failure |
B1393 | Power Door Memory Lock Relay Circuit Open |
B1394 | Power Door Memory Lock Relay Circuit Short To Battery |
B1395 | Power Door Memory Lock Relay Circuit Short To Ground |
B1396 | Power Door Lock Circuit Short To Battery |
B1397 | Power Door Unlock Circuit Short To Battery |
B1398 | Driver Power Window One Touch Window Relay Circuit Failure |
B1399 | Driver Power Window One Touch Window Relay Circuit Open |
B1400 | Driver Power Window One Touch Window Relay Circuit Short To Battery |
{mospagebreak}
B1401 | Driver Power Window One Touch Window Relay Circuit Short To Ground |
B1402 | Driver Power Window Down Switch Circuit Failure |
B1403 | Driver Power Window Up Switch Circuit Failure |
B1404 | Driver Power Window Down Circuit Open |
B1405 | Driver Power Window Down Circuit Short To Battery |
B1406 | Driver Power Window Down Circuit Short To Ground |
B1407 | Driver Power Window Up Circuit Open |
B1408 | Driver Power Window Up Circuit Short To Battery |
B1409 | Driver Power Window Up Circuit Short To Ground |
B1410 | Driver Power Window Motor Circuit Failure |
B1411 | Driver Power Window Motor Circuit Open |
B1412 | Driver Power Window Motor Circuit Short To Battery |
B1413 | Driver Power Window Motor Circuit Short To Ground |
B1414 | Power Window LR Motor Circuit Failure |
B1415 | Power Window LR Motor Circuit Open |
B1416 | Power Window LR Motor Circuit Short To Battery |
B1417 | Power Window LR Motor Circuit Short To Ground |
B1418 | Passenger Power Window Motor Circuit Failure |
B1419 | Passenger Power Window Motor Circuit Open |
B1420 | Passenger Power Window Motor Circuit Short To Battery |
B1421 | Passenger Power Window Motor Circuit Short To Ground |
B1422 | Power Window RR Motor Circuit Failure |
B1423 | Power Window RR Motor Circuit Open |
B1424 | Power Window RR Motor Circuit Short To Battery |
B1425 | Power Window RR Motor Circuit Short To Ground |
B1426 | Lamp Seat Belt Circuit Short To Battery |
B1427 | Lamp Seat Belt Circuit Open |
B1428 | Lamp Seat Belt Circuit Failure |
B1429 | Lamp Seat Belt Circuit Short To Ground |
B1430 | Seat Belt Switch Circuit Short To Ground |
B1431 | Wiper Brake/Run Relay Circuit Failure |
B1432 | Wiper Brake/Run Relay Circuit Short To Battery |
B1433 | Wiper Brake/Run Relay Circuit Short To Ground |
B1434 | Wiper Hi/Low Speed Relay Coil Circuit Failure |
B1435 | Wiper Hi/Low Speed Relay Coil Circuit Open |
B1436 | Wiper Hi/Low Speed Relay Coil Circuit Short To Battery |
B1437 | Wiper Hi/Low Speed Relay Coil Circuit Short To Ground |
B1438 | Wiper Mode Select Switch Circuit Failure |
B1439 | Wiper Mode Select Switch Circuit Open |
B1440 | Wiper Mode Select Switch Circuit Short To Battery |
{mospagebreak}
B1441 | Wiper Mode Select Switch Circuit Short To Ground |
B1442 | Door Handle Switch Circuit Failure |
B1443 | Door Handle Switch Circuit Open |
B1444 | Door Handle Switch Circuit Short To Battery |
B1445 | Door Handle Switch Circuit Short To Ground |
B1446 | Wiper Park Sense Circuit Failure |
B1447 | Wiper Park Sense Circuit Open |
B1448 | Wiper Park Sense Circuit Short To Battery |
B1449 | Wiper Park Sense Circuit Short To Ground |
B1450 | Wiper Wash/Delay Switch Circuit Failure |
B1451 | Wiper Wash/Delay Switch Circuit Open |
B1452 | Wiper Wash/Delay Switch Circuit Short To Battery |
B1453 | Wiper Wash/Delay Switch Circuit Short To Ground |
B1454 | Wiper Washer Fluid Lamp Circuit Failure |
B1455 | Wiper Washer Fluid Lamp Circuit Open |
B1456 | Wiper Washer Fluid Lamp Circuit Short To Battery |
B1457 | Wiper Washer Fluid Lamp Circuit Short To Ground |
B1458 | Wiper Washer Pump Motor Relay Circuit Failure |
B1459 | Wiper Washer Pump Motor Relay Coil Circuit Open |
B1460 | Wiper Washer Pump Motor Relay Coil Circuit Short To Battery |
B1461 | Wiper Washer Pump Motor Relay Coil Circuit Short To Ground |
B1462 | Seat Belt Switch Circuit Failure |
B1463 | Seat Belt Switch Circuit Open |
B1464 | Seat Belt Switch Circuit Short To Battery |
B1465 | Wiper Brake/Run Relay Circuit Open |
B1466 | Wiper Hi/Low Speed Not Switching |
B1467 | Wiper Hi/Low Speed Circuit Motor Short To Battery |
B1468 | Chime Input Request Circuit Failure |
B1469 | Chime Input Request Circuit Open |
B1470 | Lamp Headlamp Input Circuit Failure |
B1471 | Lamp Headlamp Input Circuit Open |
B1472 | Lamp Headlamp Input Circuit Short To Ground |
B1473 | Wiper Low Speed Circuit Motor Failure |
B1474 | Battery Saver Power Relay Circuit Short To Battery |
B1475 | Accessory Delay Relay Contact Short To Battery |
B1476 | Wiper High Speed Circuit Motor Failure |
B1477 | Wiper Hi/Low Circuit Motor Short To Ground |
B1478 | Power Window One Touch Up/Down Activated Simultaneously |
B1479 | Wiper Washer Fluid Level Sensor Circuit Failure |
B1480 | Wiper Washer Fluid Level Sensor Circuit Open |
{mospagebreak}
B1481 | Wiper Washer Fluid Level Sensor Circuit Short To Battery |
B1482 | Wiper Washer Fluid Level Sensor Circuit Short To Ground |
B1483 | Brake Pedal Input Circuit Failure |
B1484 | Brake Pedal Input Open Circuit |
B1485 | Brake Pedal Input Circuit Battery Short |
B1486 | Brake Pedal Input Circuit Ground Short |
B1487 | Door Handle Right Front Circuit Failure |
B1488 | Door Handle Right Front Circuit Open |
B1489 | Door Handle Right Front Short To Battery |
B1490 | Door Handle Right Front Short To Ground |
B1491 | Ignition Cylinder Sensor Circuit Failure |
B1492 | Ignition Cylinder Sensor Open Circuit |
B1493 | Ignition Cylinder Sensor Battery Short |
B1494 | Ignition Cylinder Sensor Ground Short |
B1495 | Decklid Punch-Out Sensor Circuit Failure |
B1496 | Decklid Punch-Out Sensor Open Circuit |
B1497 | Decklid Punch-Out Sensor Battery Short |
B1498 | Decklid Punch-Out Sensor Ground Short |
B1499 | Lamp Turn Signal Left Circuit Failure |
B1500 | Lamp Turn Signal Left Circuit Open |
B1501 | Lamp Turn Signal Left Circuit Short To Battery |
B1502 | Lamp Turn Signal Left Circuit Short To Ground |
B1503 | Lamp Turn Signal Right Circuit Failure |
B1504 | Lamp Turn Signal Right Circuit Open |
B1505 | Lamp Turn Signal Right Circuit Short To Battery |
B1506 | Lamp Turn Signal Right Circuit Short To Ground |
B1507 | Flash To Pass Switch Circuit Failure |
B1508 | Flash To Pass Switch Circuit Open |
B1509 | Flash To Pass Switch Circuit Short To Battery |
B1510 | Flash To Pass Switch Circuit Short To Ground |
B1511 | Driver Door Handle Circuit Failure |
B1512 | Driver Door Handle Circuit Open |
B1513 | Driver Door Handle Circuit Short To Battery |
B1514 | Driver Door Handle Circuit Short To Ground |
B1515 | Seat Driver Occupied Switch Circuit Failure |
B1516 | Seat Driver Occupied Switch Circuit Open |
B1517 | Seat Driver Occupied Switch Circuit Short To Battery |
B1518 | Seat Driver Occupied Switch Circuit Short To Ground |
B1519 | Hood Switch Circuit Failure |
B1520 | Hood Switch Circuit Open |
{mospagebreak}
B1521 | Hood Switch Circuit Short To Battery |
B1522 | Hood Switch Circuit Short To Ground |
B1523 | Keyless Entry Circuit Failure |
B1524 | Keyless Entry Circuit Open |
B1525 | Keyless Entry Circuit Short To Battery |
B1526 | Keyless Entry Circuit Short To Ground |
B1527 | Memory Set Switch Circuit Failure |
B1528 | Memory Set Switch Circuit Open |
B1529 | Memory Set Switch Circuit Short To Battery |
B1530 | Memory Set Switch Circuit Short To Ground |
B1531 | Memory 1 Switch Circuit Failure |
B1532 | Memory 1 Switch Circuit Open |
B1533 | Memory 1 Switch Circuit Short To Battery |
B1534 | Memory 1 Switch Circuit Short To Ground |
B1535 | Memory 2 Switch Circuit Failure |
B1536 | Memory 2 Switch Circuit Open |
B1537 | Memory 2 Switch Circuit Short To Battery |
B1538 | Memory 2 Switch Circuit Short To Ground |
B1539 | Mirror Driver Switch Assembly Circuit Failure |
B1540 | Mirror Driver Switch Assembly Circuit Open |
B1541 | Mirror Driver Switch Assembly Circuit Short To Battery |
B1542 | Mirror Driver Switch Assembly Circuit Short To Ground |
B1543 | Seat Direction Switch Assembly Circuit Failure |
B1544 | Seat Direction Switch Assembly Circuit Open |
B1545 | Seat Direction Switch Assembly Circuit Short To Battery |
B1546 | Seat Direction Switch Assembly Circuit Short To Ground |
B1547 | Power Window Master Circuit Failure |
B1548 | Power Window Master Circuit Open |
B1549 | Power Window Master Circuit Short To Battery |
B1550 | Power Window Master Circuit Short To Ground |
B1551 | Decklid Release Circuit Failure |
B1552 | Decklid Release Circuit Open |
B1553 | Decklid Release Circuit Short To Battery |
B1554 | Decklid Release Circuit Short To Ground |
B1555 | Ignition Run/Start Circuit Failure |
B1556 | Ignition Run/Start Circuit Open |
B1557 | Ignition Run/Start Circuit Short To Battery |
B1558 | Ignition Run/Start Circuit Short To Ground |
B1559 | Door Lock Cylinder Circuit Failure |
B1560 | Door Lock Cylinder Circuit Open |
{mospagebreak}
B1561 | Door Lock Cylinder Circuit Short To Battery |
B1562 | Door Lock Cylinder Circuit Short To Ground |
B1563 | Door Ajar Circuit Failure |
B1564 | Door Ajar Circuit Open |
B1565 | Door Ajar Circuit Short To Battery |
B1566 | Door Ajar Circuit Short To Ground |
B1567 | Lamp Headlamp High-Beam Circuit Failure |
B1568 | Lamp Headlamp High-Beam Circuit Open |
B1569 | Lamp Headlamp High-Beam Circuit Short To Battery |
B1570 | Lamp Headlamp High-Beam Circuit Short To Ground |
B1571 | Door Ajar LR Circuit Failure |
B1572 | Door Ajar LR Circuit Open |
B1573 | Door Ajar LR Circuit Short To Battery |
B1574 | Door Ajar LR Circuit Short To Ground |
B1575 | Lamp Park Input Circuit Failure |
B1576 | Lamp Park Input Circuit Open |
B1577 | Lamp Park Input Circuit Short To Battery |
B1578 | Lamp Park Input Circuit Short To Ground |
B1579 | Dim Panel Increase Input Circuit Failure |
B1580 | Dim Panel Increase Input Circuit Open |
B1581 | Dim Panel Increase Input Circuit Short To Battery |
B1582 | Dim Panel Increase Input Circuit Short To Ground |
B1583 | Dim Panel Decrease Input Circuit Failure |
B1584 | Dim Panel Decrease Input Circuit Open |
B1585 | Dim Panel Decrease Input Circuit Short To Battery |
B1586 | Dim Panel Decrease Input Circuit Short To Ground |
B1587 | Autolamp Delay Increase Circuit Failure |
B1588 | Autolamp Delay Increase Circuit Open |
B1589 | Autolamp Delay Increase Circuit Short To Battery |
B1590 | Autolamp Delay Increase Circuit Short To Ground |
B1591 | Autolamp Delay Decrease Circuit Failure |
B1592 | Autolamp Delay Decrease Circuit Open |
B1593 | Autolamp Delay Decrease Circuit Short To Battery |
B1594 | Autolamp Delay Decrease Circuit Short To Ground |
B1595 | Ignition Switch Illegal Input Code |
B1596 | Service Continuous Codes |
B1597 | Driver's Seat Seatback Autoglide Forward Switch Circuit Short to Ground |
B1598 | Driver's Seat Seatback Autoglide Rearward Switch Circuit Short to Ground |
B1599 | Passenger's Seatback Autoglide Forward Switch Circuit Short to Ground |
B1600 | PATS Ignition Key Transponder Signal Is Not Received |
{mospagebreak}
B1601 | PATS Received Incorrect Key-Code From Ignition Key Transponder |
B1602 | PATS Received Invalid Format Of Key-Code From Ignition Key Transponder |
B1603 | Lamp Anti-Theft Indicator Circuit Failure |
B1604 | Lamp Anti-Theft Indicator Circuit Open |
B1605 | Lamp Anti-Theft Indicator Circuit Short To Battery |
B1606 | Lamp Anti-Theft Indicator Circuit Short To Ground |
B1607 | Illuminated Entry Input Circuit Failure |
B1608 | Illuminated Entry Input Open Circuit |
B1609 | Illuminated Entry Input Short Circuit To Battery |
B1610 | Illuminated Entry Input Short Circuit To Ground |
B1611 | Wiper Rear Mode Select Switch Circuit Failure |
B1612 | Wiper Rear Mode Select Switch Circuit Open |
B1613 | Wiper Rear Mode Select Switch Circuit Short To Battery |
B1614 | Wiper Rear Mode Select Switch Circuit Short To Ground |
B1615 | Wiper Rear Disable Switch Circuit Failure |
B1616 | Wiper Rear Disable Switch Circuit Open |
B1617 | Wiper Rear Disable Switch Circuit Short To Battery |
B1618 | Wiper Rear Disable Switch Circuit Short To Ground |
B1619 | Wiper Rear Low Limit Input Circuit Failure |
B1620 | Wiper Rear Low Limit Input Circuit Open |
B1621 | Wiper Rear Low Limit Input Circuit Short To Battery |
B1622 | Wiper Rear Low Limit Input Circuit Short To Ground |
B1623 | Lamp Keypad Output Circuit Failure |
B1624 | Lamp Keypad Output Open Circuit |
B1625 | Lamp Keypad Output Short Circuit To Battery |
B1626 | Lamp Keypad Output Short Circuit To Ground |
B1627 | PRNDL Reverse Input Circuit Failure |
B1628 | PRNDL Reverse Input Open Circuit |
B1629 | PRNDL Reverse Input Short To Battery |
B1630 | PRNDL Reverse Input Short Circuit To Ground |
B1631 | Mirror Driver Left Circuit Failure |
B1632 | Mirror Driver Left Circuit Open |
B1633 | Mirror Driver Left Circuit Short To Battery |
B1634 | Mirror Driver Left Circuit Short To Ground |
B1635 | Mirror Driver Right Circuit Failure |
B1636 | Mirror Driver Right Circuit Open |
B1637 | Mirror Driver Right Circuit Short To Battery |
B1638 | Mirror Driver Right Short To Ground |
B1639 | Mirror Passenger Left Circuit Failure |
B1640 | Mirror Passenger Left Circuit Open |
{mospagebreak}
B1641 | Mirror Passenger Left Circuit Short To Battery |
B1642 | Mirror Passenger Left Circuit Short To Ground |
B1643 | Mirror Passenger Right Circuit Failure |
B1644 | Mirror Passenger Right Circuit Open |
B1645 | Mirror Passenger Right Circuit Short To Battery |
B1646 | Mirror Passenger Right Circuit Short To Ground |
B1647 | Seat Driver Recline Forward Circuit Failure |
B1648 | Seat Driver Recline Forward Circuit Open |
B1649 | Seat Driver Recline Forward Circuit Short To Battery |
B1650 | Seat Driver Recline Forward Circuit Short To Ground |
B1651 | Seat Driver Recline Backward Circuit Failure |
B1652 | Seat Driver Recline Backward Circuit Open |
B1653 | Seat Driver Recline Backward Circuit Short To Battery |
B1654 | Seat Driver Recline Backward Circuit Short To Ground |
B1655 | Seat Driver Rear Up Circuit Failure |
B1656 | Seat Driver Rear Up Circuit Open |
B1657 | Seat Driver Rear Up Circuit Short To Battery |
B1658 | Seat Driver Rear Up Circuit Short To Ground |
B1659 | Seat Driver Front Up Circuit Failure |
B1660 | Seat Driver Front Up Circuit Open |
B1661 | Seat Driver Front Up Circuit Short To Battery |
B1662 | Seat Driver Front Up Circuit Short To Ground |
B1663 | Seat Driver Front Up/Down Motor Stalled |
B1664 | Seat Driver Rear Up/Down Motor Stalled |
B1665 | Seat Driver Forward/Backward Motor Stalled |
B1666 | Seat Driver Recline Motor Stalled |
B1667 | Mirror Driver Up/Down Motor Stalled |
B1668 | Mirror Driver Right/Left Motor Stalled |
B1669 | Mirror Passenger Up/Down Motor Stalled |
B1670 | Mirror Passenger Right/Left Motor Stalled |
B1671 | Battery Module Voltage Out Of Range |
B1672 | Seat Driver Occupied Input Circuit Failure |
B1673 | Seat Driver Occupied Input Circuit Open |
B1674 | Seat Driver Occupied Input Circuit Short To Battery |
B1675 | Seat Driver Occupied Input Circuit Short To Ground |
B1676 | Battery Pack Voltage Out Of Range |
B1677 | Alarm Panic Input Circuit Failure |
B1678 | Alarm Panic Input Circuit Open |
B1679 | Alarm Panic Input Circuit Short To Battery |
B1680 | Alarm Panic Input Circuit Short To Ground |
{mospagebreak}
B1681 | PATS Transceiver Module Signal Is Not Received |
B1682 | PATS Is Disabled (Check Link Between PATS And Transponder) |
B1683 | Mirror Driver/Passenger Switch Circuit Failure |
B1684 | Mirror Driver/Passenger Switch Circuit Open |
B1685 | Lamp Dome Input Circuit Failure |
B1686 | Lamp Dome Input Circuit Open |
B1687 | Lamp Dome Input Circuit Short To Battery |
B1688 | Lamp Dome Input Circuit Short To Ground |
B1689 | Autolamp Delay Circuit Failure |
B1690 | Autolamp Delay Circuit Open |
B1691 | Autolamp Delay Circuit Short To Battery |
B1692 | Autolamp Delay Circuit Short To Ground |
B1693 | Autolamp On Circuit Failure |
B1694 | Autolamp On Circuit Open |
B1695 | Autolamp On Circuit Short To Battery |
B1696 | Autolamp On Circuit Short To Ground |
B1697 | Mirror Driver/Passenger Switch Circuit Short To Battery |
B1698 | Mirror Driver/Passenger Switch Circuit Short To Ground |
B1699 | Passenger's Seat Occupied Switch Circuit Short to Ground |
B1700 | Passenger's Seatbelt Tension Reducer Circuit Short to Ground |
B1701 | Seat Driver Recline Forward Switch Circuit Failure |
B1702 | Seat Driver Recline Forward Switch Circuit Open |
B1703 | Seat Driver Recline Forward Switch Circuit Short To Battery |
B1704 | Seat Driver Recline Forward Switch Circuit Short To Ground |
B1705 | Seat Driver Recline Rearward Switch Circuit Failure |
B1706 | Seat Driver Recline Rearward Switch Circuit Open |
B1707 | Seat Driver Recline Rearward Switch Circuit Short To Battery |
B1708 | Seat Driver Recline Rearward Switch Circuit Short To Ground |
B1709 | Seat Driver Front Up Switch Circuit Failure |
B1710 | Seat Driver Front Up Switch Circuit Open |
B1711 | Seat Driver Front Up Switch Circuit Short To Battery |
B1712 | Seat Driver Front Up Switch Circuit Short To Ground |
B1713 | Seat Driver Front Down Switch Circuit Failure |
B1714 | Seat Driver Front Down Switch Circuit Open |
B1715 | Seat Driver Front Down Switch Circuit Short To Battery |
B1716 | Seat Driver Front Down Switch Circuit Short To Ground |
B1717 | Seat Driver Forward Switch Circuit Failure |
B1718 | Seat Driver Forward Switch Circuit Open |
B1719 | Seat Driver Forward Switch Circuit Short To Battery |
B1720 | Seat Driver Forward Switch Circuit Short To Ground |
{mospagebreak}
B1721 | Seat Driver Rearward Switch Circuit Failure |
B1722 | Seat Driver Rearward Switch Circuit Open |
B1723 | Seat Driver Rearward Switch Circuit Short To Battery |
B1724 | Seat Driver Rearward Switch Circuit Short To Ground |
B1725 | Seat Driver Rear Up Switch Circuit Failure |
B1726 | Seat Driver Rear Up Switch Circuit Open |
B1727 | Seat Driver Rear Up Switch Circuit Short To Battery |
B1728 | Seat Driver Rear Up Switch Circuit Short To Ground |
B1729 | Seat Driver Rear Down Switch Circuit Failure |
B1730 | Seat Driver Rear Down Switch Circuit Open |
B1731 | Seat Driver Rear Down Switch Circuit Short To Battery |
B1732 | Seat Driver Rear Down Switch Circuit Short To Ground |
B1733 | Mirror Driver Vertical Switch Circuit Failure |
B1734 | Mirror Driver Vertical Switch Circuit Open |
B1735 | Mirror Driver Vertical Switch Circuit Short To Battery |
B1736 | Mirror Driver Vertical Switch Circuit Short To Ground |
B1737 | Mirror Driver Horizontal Switch Circuit Failure |
B1738 | Mirror Driver Horizontal Switch Circuit Open |
B1739 | Mirror Driver Horizontal Switch Circuit Short To Battery |
B1740 | Mirror Driver Horizontal Switch Circuit Short To Ground |
B1741 | Mirror Passenger Vertical Switch Circuit Failure |
B1742 | Mirror Passenger Vertical Switch Circuit Open |
B1743 | Mirror Passenger Vertical Switch Circuit Short To Battery |
B1744 | Mirror Passenger Vertical Switch Circuit Short To Ground |
B1745 | Mirror Passenger Horizontal Switch Circuit Failure |
B1746 | Mirror Passenger Horizontal Switch Circuit Open |
B1747 | Mirror Passenger Horizontal Switch Circuit Short To Battery |
B1748 | Mirror Passenger Horizontal Switch Circuit Short To Ground |
B1749 | Park/Neutral Switch Circuit Failure |
B1750 | Park/Neutral Switch Circuit Open |
B1751 | Park/Neutral Switch Circuit Short To Battery |
B1752 | Park/Neutral Switch Circuit Short To Ground |
B1753 | Hazard Flash Output Circuit Failure |
B1754 | Hazard Flash Output Circuit Open |
B1755 | Hazard Flash Output Circuit Short Battery |
B1756 | Hazard Flash Output Circuit Short To Ground |
B1757 | Seat Driver Rear Down Circuit Failure |
B1758 | Seat Driver Rear Down Circuit Open |
B1759 | Seat Driver Rear Down Circuit Short To Battery |
B1760 | Seat Driver Rear Down Circuit Short To Ground |
{mospagebreak}
B1761 | Seat Driver Front Down Circuit Failure |
B1762 | Seat Driver Front Down Circuit Open |
B1763 | Seat Driver Front Down Circuit Short To Battery |
B1764 | Seat Driver Front Down Circuit Short To Ground |
B1765 | Seat Driver Forward Circuit Failure |
B1766 | Seat Driver Forward Circuit Open |
B1767 | Seat Driver Forward Circuit Short To Battery |
B1768 | Seat Driver Forward Circuit Short To Ground |
B1769 | Seat Driver Backward Circuit Failure |
B1770 | Seat Driver Backward Circuit Open |
B1771 | Seat Driver Backward Circuit Short To Battery |
B1772 | Seat Driver Backward Circuit Short To Ground |
B1773 | Mirror Driver Up Circuit Failure |
B1774 | Mirror Driver Up Circuit Open |
B1775 | Mirror Driver Up Circuit Short To Battery |
B1776 | Mirror Driver Up Circuit Short To Ground |
B1777 | Driver's Seatbelt Tension Reducer Circuit Short to Ground |
B1778 | Mirror Driver Down Circuit Failure |
B1779 | Mirror Driver Down Circuit Open |
B1780 | Mirror Driver Down Circuit Short To Battery |
B1781 | Mirror Driver Down Short To Ground |
B1782 | Mirror Passenger Up Circuit Failure |
B1783 | Mirror Passenger Up Circuit Open |
B1784 | Mirror Passenger Up Circuit Short To Battery |
B1785 | Mirror Passenger Up Circuit Short To Ground |
B1786 | Mirror Passenger Down Circuit Failure |
B1787 | Mirror Passenger Down Circuit Open |
B1788 | Mirror Passenger Down Circuit Short To Battery |
B1789 | Mirror Passenger Down Circuit Short To Ground |
B1790 | Autolamp Sensor Input Circuit Failure |
B1791 | Autolamp Sensor Input Circuit Open |
B1792 | Autolamp Sensor Input Circuit Short To Battery |
B1793 | Autolamp Sensor Input Circuit Short To Ground |
B1794 | Lamp Headlamp Low-Beam Circuit Failure |
B1795 | Lamp Headlamp Low-Beam Circuit Open |
B1796 | Lamp Headlamp Low-Beam Circuit Short To Battery |
B1797 | Lamp Headlamp Low-Beam Circuit Short To Ground |
B1798 | Lamp Turn Signal Front Output Circuit Failure |
B1799 | Lamp Turn Signal Front Output Circuit Open |
B1800 | Lamp Turn Signal Front Output Circuit Short To Battery |
{mospagebreak}
B1801 | Lamp Turn Signal Front Output Circuit Short To Ground |
B1802 | Lamp Turn Signal Rear Output Circuit Failure |
B1803 | Lamp Turn Signal Rear Output Circuit Open |
B1804 | Lamp Turn Signal Rear Output Circuit Short To Battery |
B1805 | Lamp Turn Signal Rear Output Circuit Short To Ground |
B1806 | Lamp Tail Output Circuit Failure |
B1807 | Lamp Tail Output Circuit Open |
B1808 | Lamp Tail Output Circuit Short To Battery |
B1809 | Lamp Tail Output Circuit Short To Ground |
B1810 | Lamp Backup Switch Input Circuit Failure |
B1811 | Lamp Backup Switch Input Circuit Open |
B1812 | Lamp Backup Switch Input Circuit Short To Battery |
B1813 | Lamp Backup Switch Input Circuit Short To Ground |
B1814 | Wiper Rear Motor Down Relay Coil Circuit Failure |
B1815 | Wiper Rear Motor Down Relay Coil Circuit Open |
B1816 | Wiper Rear Motor Down Relay Coil Circuit Short To Battery |
B1817 | Wiper Rear Motor Down Relay Coil Circuit Short To Ground |
B1818 | Wiper Rear Motor Up Relay Coil Circuit Failure |
B1819 | Wiper Rear Motor Up Relay Coil Circuit Open |
B1820 | Wiper Rear Motor Up Relay Coil Circuit Short To Battery |
B1821 | Wiper Rear Motor Up Relay Coil Circuit Short To Ground |
B1822 | Wiper Rear Park Sense Input Circuit Failure |
B1823 | Wiper Rear Park Sense Input Circuit Open |
B1824 | Wiper Rear Park Sense Input Circuit Short To Battery |
B1825 | Wiper Rear Park Sense Input Circuit Short To Ground |
B1826 | Wiper Rear High Limit Input Circuit Failure |
B1827 | Wiper Rear High Limit Input Circuit Open |
B1828 | Wiper Rear High Limit Input Circuit Short To Battery |
B1829 | Wiper Rear High Limit Input Circuit Short To Ground |
B1830 | Door Unlock Disarm Switch Circuit Failure |
B1831 | Door Unlock Disarm Switch Circuit Open |
B1832 | Door Unlock Disarm Switch Circuit Short To Battery |
B1833 | Door Unlock Disarm Switch Circuit Short To Ground |
B1834 | Door Unlock Disarm Output Circuit Failure |
B1835 | Door Unlock Disarm Output Circuit Open |
B1836 | Door Unlock Disarm Output Circuit Short To Battery |
B1837 | Door Unlock Disarm Output Circuit Short To Ground |
B1838 | Battery Saver Power Relay Circuit Failure |
B1839 | Wiper Rear Motor Circuit Failure |
B1840 | Wiper Front Power Circuit Failure |
{mospagebreak}
B1841 | Wiper Front Power Circuit Open |
B1842 | Wiper Front Power Circuit Short To Battery |
B1843 | Wiper Front Power Circuit Short To Ground |
B1844 | Phone Handset Circuit Failure |
B1845 | Ignition Tamper Circuit Failure |
B1846 | Ignition Tamper Circuit Open |
B1847 | Ignition Tamper Circuit Short To Battery |
B1848 | Ignition Tamper Circuit Short To Ground |
B1849 | Climate Control Temperature Differential Circuit Failure |
B1850 | Climate Control Temperature Differential Circuit Open |
B1851 | Climate Control Temperature Differential Circuit Short To Battery |
B1852 | Climate Control Temperature Differential Circuit Short To Ground |
B1853 | Climate Control Air Temperature Internal Sensor Motor Circuit Failure |
B1854 | Climate Control Air Temperature Internal Sensor Motor Circuit Open |
B1855 | Climate Control Air Temperature Internal Sensor Motor Circuit Short To Battery |
B1856 | Climate Control Air Temperature Internal Sensor Motor Circuit Short To Ground |
B1857 | Climate Control On/Off Switch Circuit Failure |
B1858 | Climate Control A/C Pressure Switch Circuit Failure |
B1859 | Climate Control A/C Pressure Switch Circuit Open |
B1860 | Climate Control A/C Pressure Switch Circuit Short To Battery |
B1861 | Climate Control A/C Pressure Switch Circuit Short To Ground |
B1862 | Climate Control A/C Lock Sensor Failure |
B1863 | Ground ECU Circuit Open |
B1864 | Battery Power Supply ECU Circuit Failure |
B1865 | Battery Power Supply ECU Circuit Open |
B1866 | Battery Power Supply ECU Circuit Short To Battery |
B1867 | Battery Power Supply ECU Circuit Short To Ground |
B1868 | Lamp Air Bag Warning Indicator Circuit Failure |
B1869 | Lamp Air Bag Warning Indicator Circuit Open |
B1870 | Lamp Air Bag Warning Indicator Circuit Short To Battery |
B1871 | Passenger Air Bag Disable Module Fault |
B1872 | Turn Signal / Hazard Power Feed Circuit Short To Battery |
B1873 | Turn Signal / Hazard Power Feed Circuit Short To Ground |
B1874 | Cellular Phone Handset Not Present |
B1875 | Turn Signal / Hazard Switch Signal Circuit Failure |
B1876 | Seatbelt Driver Pretensioner Circuit Failure |
B1877 | Seatbelt Driver Pretensioner Circuit Open |
B1878 | Seatbelt Driver Pretensioner Circuit Short to Battery |
B1879 | Seatbelt Driver Pretensioner Circuit Short to Ground |
B1880 | Seatbelt Passenger Pretensioner Circuit Failure |
{mospagebreak}
B1881 | Seatbelt Passenger Pretensioner Circuit Open |
B1882 | Seatbelt Passenger Pretensioner Circuit Short to Battery |
B1883 | Seatbelt Passenger Pretensioner Circuit Short to Ground |
B1884 | PAD Warning Lamp Inoperative |
B1885 | Seatbelt Driver Pretensioner Circuit Resistance Low on Squib |
B1886 | Seatbelt Passenger Pretensioner Circuit Resistance Low on Squib |
B1887 | Air Bag Driver Circuit Resistance Low or Shorted Together |
B1888 | Air Bag Passenger Circuit Resistance Low or Shorted Together |
B1889 | Passenger Airbag Disable Module Sensor Obstructed |
B1890 | PAD Warning Lamp Circuit Short to Battery |
B1891 | Air Bag Tone Warning Indicator Circuit Short to Battery |
B1892 | Air Bag Tone Warning Indicator Circuit Failure |
B1893 | GPS Antenna Open Circuit |
B1894 | Wiper Rear Motor Speed Sense Circuit Failure |
B1895 | Driver's / Passenger's Door Ajar Output Circuit Failure |
B1896 | Driver's / Passenger's Door Ajar Output Circuit Short to Battery |
B1897 | Horn Switch Circuit Failure |
B1898 | Chime Input #2 Circuit Short to Ground |
B1899 | Microphone Input Signal Circuit Open |
B1900 | Driver Side Airbag Fault |
B1901 | Air Bag Crash Sensor #1 Feed/Return Circuit Short To Ground |
B1902 | Air Bag Crash Sensor #1 Ground Circuit Failure |
B1903 | Air Bag Crash Sensor #1 Ground Circuit Short To Battery |
B1904 | Air Bag Crash Sensor #2 Feed/Return Circuit Failure |
B1905 | Air Bag Crash Sensor #2 Feed/Return Circuit Short To Battery |
B1906 | Air Bag Crash Sensor #2 Feed/Return Circuit Short To Ground |
B1907 | Air Bag Crash Sensor #2 Ground Circuit Failure |
B1908 | Air Bag Crash Sensor #2 Ground Circuit Short To Battery |
B1909 | Air Bag Crash Sensor #2 Ground Circuit Short To Ground |
B1910 | Air Bag Diagnostic Monitor Ground Circuit Failure |
B1911 | Air Bag Diagnostic Monitor Ground Circuit Short To Battery |
B1912 | Air Bag Diagnostic Monitor Ground Circuit Short To Ground |
B1913 | Air Bag Driver/Passenger Circuit Short To Ground |
B1914 | Air Bag Crash Sensors #1 / #2 Circuit Short To Ground |
B1915 | Air Bag Driver Circuit Failure |
B1916 | Air Bag Driver Circuit Short To Battery |
B1917 | Air Bag Memory Clear Circuit Failure |
B1918 | Air Bag Memory Clear Circuit Open |
B1919 | Air Bag Memory Clear Circuit Short To Battery |
B1920 | Air Bag Passenger Circuit Failure |
{mospagebreak}
B1921 | Air Bag Diagnostic Monitor Ground Circuit Open |
B1922 | Air Bag Safing Sensor Output Circuit Short To Battery |
B1923 | Air Bag Memory Clear Circuit Short To Ground |
B1924 | Air Bag Internal Diagnostic Monitor Fault or System Disarm Fault |
B1925 | Air Bag Passenger Circuit Short To Battery |
B1926 | Air Bag Passenger Pressure Switch Circuit Failure |
B1927 | Passenger Side Airbag Fault |
B1928 | Air Bag Safing Sensor Output Circuit Failure |
B1929 | Air Bag Safing Sensor Output Circuit Open |
B1930 | Air Bag Safing Sensor Output Circuit Short To Ground |
B1931 | Air Bag Crash Sensor #1 Feed/Return Circuit Failure |
B1932 | Air Bag Driver Circuit Open |
B1933 | Air Bag Passenger Circuit Open |
B1934 | Air Bag Driver Inflator Circuit Resistance Low on Squib |
B1935 | Air Bag Passenger Inflator Circuit Resistance Low on Squib |
B1936 | Air Bag Driver Circuit Short To Ground |
B1937 | Air Bag Passenger Pressure Switch Circuit Open |
B1938 | Air Bag Passenger Circuit Short To Ground |
B1939 | Air Bag Passenger Pressure Switch Circuit Short To Ground |
B1941 | Air Bag Crash Sensor #1 Feed/Return Circuit Open |
B1942 | Air Bag Crash Sensor #2 Feed/Return Circuit Open |
B1943 | Air Bag Crash Sensor #1 Ground Circuit Short To Ground |
B1944 | Air Bag Crash Sensor #1 Ground Circuit Open |
B1945 | Air Bag Crash Sensor #2 Ground Circuit Open |
B1946 | Climate Control A/C Post Evaporator Sensor Circuit Failure |
B1947 | Climate Control A/C Post Evaporator Sensor Circuit Short To Ground |
B1948 | Climate Control Water Temperature Sensor Circuit Failure |
B1949 | Climate Control Water Temperature Sensor Circuit Short To Ground |
B1950 | Seat Rear Up/Down Potentiometer Feedback Circuit Failure |
B1951 | Seat Rear Up/Down Potentiometer Feedback Circuit Open |
B1952 | Seat Rear Up/Down Potentiometer Feedback Circuit Short To Battery |
B1953 | Seat Rear Up/Down Potentiometer Feedback Circuit Short To Ground |
B1954 | Seat Front Up/Down Potentiometer Feedback Circuit Failure |
B1955 | Seat Front Up/Down Potentiometer Feedback Circuit Open |
B1956 | Seat Front Up/Down Potentiometer Feedback Circuit Short To Battery |
B1957 | Seat Front Up/Down Potentiometer Feedback Circuit Short To Ground |
B1958 | Seat Recline Forward/Backward Potentiometer Feedback Circuit Failure |
B1959 | Seat Recline Forward/Backward Potentiometer Feedback Circuit Open |
B1960 | Seat Recline Forward/Backward Potentiometer Feedback Circuit Short To Battery |
{mospagebreak}
B1961 | Seat Recline Forward/Backward Potentiometer Feedback Circuit Short To Ground |
B1962 | Seat Horizontal Forward/Rearward Potentiometer Feedback Circuit Failure |
B1963 | Seat Horizontal Forward/Rearward Potentiometer Feedback Circuit Open |
B1964 | Seat Horizontal Forward/Rearward Potentiometer Feedback Circuit Short To Battery |
B1965 | Seat Horizontal Forward/Rearward Potentiometer Feedback Circuit Short To Ground |
B1966 | A/C Post Heater Sensor Circuit Failure |
B1967 | A/C Post Heater Sensor Circuit Short To Ground |
B1968 | A/C Water Pump Detection Circuit Failure |
B1969 | A/C Clutch Magnetic Control Circuit Failure |
B1970 | Passenger Seatback Forward Switch Circuit Short to Ground |
B1971 | Passenger Seatback Rearward Switch Circuit Short to Ground |
B1972 | Passenger Rear Seat Up Switch Circuit Short to Battery |
B1973 | Passenger Rear Seat Down Switch Circuit Short to Battery |
B1974 | Passenger's Seat Recline Forward Switch Circuit Short to Battery |
B1975 | Passenger's Seat Recline Back Switch Circuit Short to Battery |
B1976 | Passenger's Seat Forward Switch Circuit Short to Battery |
B1977 | Passenger's Front Seat Up Switch Circuit Short to Battery |
B1978 | Passenger's Front Seat Down Switch Circuit Short to Battery |
B1979 | Passenger Seat Rearward Switch Circuit Short to Battery |
B1980 | Bulb – Outage Condition Detected |
B1981 | Memory Off Switch Circuit Short to Battery |
B1982 | Driver's Door Unlock Relay Circuit Failure |
B1983 | Driver's Door Unlock Relay Circuit Short to Battery |
B1984 | Seat Switch Lumbar Inflate Circuit Failure |
B1985 | Seat Switch Lumbar Deflate Circuit Failure |
B1986 | Driver's Seat Seatback Autoglide Rearward Switch Circuit Failure |
B1987 | Pedal Forward / Rearward Motor Stalled |
B1988 | Pedal Position Forward Switch Circuit Short to Battery |
B1989 | Pedal Position Rearward Switch Circuit Short to Battery |
B1990 | Pedal Forward / Rearward Potentiometer Feedback Circuit Failure |
B1991 | Pedal Forward / Rearward Potentiometer Feedback Circuit Short to Battery |
B1992 | Driver Side, Side mount Airbag Circuit Short to Vbatt |
B1993 | Driver Side, Side mount Airbag Circuit Short to Ground |
B1994 | Driver Side, Side mount Airbag Circuit Open |
B1995 | Driver Side, Side mount Airbag Low resistance on Squib |
B1996 | Passenger Side, Side mount Airbag Circuit Short to Vbatt |
B1997 | Passenger Side, Side mount Airbag Circuit Short to Ground |
B1998 | Passenger Side, Side mount Airbag Circuit Open |
B1999 | Passenger Side, Side mount Airbag Low resistance on Squib |
B2100 | Door Driver Key Cylinder Switch Failure |
{mospagebreak}
B2101 | Head Rest Switch Circuit Failure |
B2102 | Antenna Circuit Short to Ground |
B2103 | Antenna Not Connected |
B2104 | Door Passenger Key Cylinder Switch Failure |
B2105 | Throttle Position Input Out of Range Low |
B2106 | Throttle Position Input Out of Range High |
B2107 | Front Wiper Motor Relay Circuit Short to Vbatt |
B2108 | Trunk Key Cylinder Switch Failure |
B2109 | Heated Wind Shield Relay Short to Vbatt (changed from Failure 2/6/97) |
B2110 | Front Wiper Motor Relay Circuit Open (changed from Failure 2/6/97) |
B2111 | All Door Lock Input Short to Ground |
B2112 | Door Driver Set Switch Stuck Failure |
B2113 | Heated Windshield Input Short to Ground |
B2114 | Front Washer Input Short to Ground |
B2115 | Rear Washer Input Short to Ground |
B2116 | Door Driver Reset Switch Stuck Failure |
B2117 | Driver Side, Side mount Airbag Low capacitance on Squib |
B2118 | Passenger Side, Side mount Airbag Low capacitance on Squib |
B2119 | Compressor Failure |
B2120 | Door Passenger Set Switch Stuck Failure |
B2122 | Driver Side Satellite Communication Circuit Short to Ground |
B2123 | Passenger Side Satellite Communication Circuit Short to Ground |
B2124 | Door Passenger Reset Switch Stuck Failure |
B2128 | Central Lock Motor Failure |
B2129 | Central Lock Feedback Failure |
B2130 | Double Lock Timeout Failure |
B2131 | Double Lock Feedback Failure |
B2132 | Dimmer switch Circuit Short to Gnd |
B2133 | Brake Motor Warning lamp Circuit Failure |
B2134 | Brake Motor Warning lamp Circuit Short to Vbatt |
B2135 | Park Brake Applied Warning Lamp Circuit Failure |
B2136 | Park Brake Applied Warning Lamp Circuit Short To Battery |
B2139 | Data Mismatch (receive data does not match what was expected) |
{mospagebreak}
B2141 | NVM Configuration Failure |
B2142 | NVM TIC Failure |
B2143 | NVM Memory Failure |
B2144 | NVM Alarm Data Failure |
B2145 | NVM RF HR Failure |
B2146 | Seat Recline Motor Position Out of Range |
B2148 | PWM Input Circuit Failure |
B2149 | Seat Front Vertical Motor Position Out of Range |
B2150 | Power Supply #1 Circuit Short to Ground |
B2151 | Power Supply #2 Circuit Short to Ground |
B2152 | Seat Rear Vertical Motor Position Out of Range |
B2153 | Rear Echo Sensor Circuit Failure |
B2154 | Front Echo Sensor Circuit Failure |
B2155 | Seat Horizontal Motor Position Out of Range |
B2156 | Rear Doppler Sensor Circuit Failure |
B2157 | Front Doppler Sensor Circuit Failure |
B2158 | Seat Recline Motor Memory Position Out of Range |
B2159 | Memory #1 output Short to Ground |
B2160 | Memory #1 output Short to VBatt |
B2161 | Seat Front Vertical Motor Memory Position Out of Range |
B2162 | Data Mismatch #2 (receive data does not match what was expected) |
B2163 | Clutch Position Fault |
B2164 | Seat Rear Vertical Motor Memory Position Out of Range |
B2165 | Gear shift position Fault |
B2166 | Gear select position Fault |
B2167 | Seat Horizontal Motor Memory Position Out of Range |
B2168 | Unable to confirm Unlock Condition |
B2169 | Unable to confirm lock Condition |
B2170 | Steering Column Lock Switch Circuit Failure |
B2172 | Inertia Switch input Circuit Open |
B2174 | Window Driver Rear Remote Up Switch Short to Battery |
B2175 | A/C Request Signal Circuit Short to Ground |
B2176 | Overdrive switch circuit short to Vbatt |
B2177 | Interior Scanning Sensor Circuit Failure |
B2178 | Window Driver Rear Remote Down Switch Short to Battery |
B2179 | Front Wiper Select Switch "A" Short to Ground |
B2180 | Front Wiper Select Switch "B" Short to Ground |
{mospagebreak}
B2181 | Front Wiper Select Switch "C" Short to Ground |
B2182 | Window Passenger Front Remote Up Switch Short to Battery |
B2183 | Front Wiper Select Switch "H" Short to Ground |
B2184 | Front Wiper Select Switch "W" Short to Ground |
B2185 | Rear Wiper Select Switch "D" Short to Ground |
B2186 | Window Passenger Front Remote Down Switch Short to Battery |
B2187 | Rear Wiper Select Switch "B" Short to Ground |
B2188 | Rear Wiper Select Switch "E" Short to Ground |
B2190 | Window Passenger Rear Remote Up Switch Short to Battery |
B2194 | Window Passenger Rear Remote Down Switch Short to Battery |
B2195 | Driver Window Up / Down Power Circuit Short to Ground |
B2196 | Passenger Window Up / Down Power Circuit Short to Ground |
B2197 | TV Module Error |
B2198 | TrafficMaster Module Error |
B2199 | VICS Module Error |
B2200 | No Communication to TV Module (No Fitting of TV) |
B2201 | No Communication With Traffic MasterModule |
B2202 | No Communication to VICS Module (No Fitting of VICS) |
B2203 | CD-ROM Error |
B2204 | GPS Antenna Connection Open or Short |
B2205 | GPS Receiver Error |
B2206 | Gyroscope Error |
B2207 | ECU ROM Checksum Error |
B2208 | Communication Link to Display and Switch Module Error |
B2209 | Interior Lamp Override Switch Open Circuit |
B2210 | Interior Lamp Override Switch Short to Ground |
B2211 | Low Coolant Lamp Output Circuit Short to Battery |
B2214 | Window Passenger Front Up Switch Short to Battery |
B2215 | Window Passenger Front Down Switch Short to Battery |
B2219 | Window Driver Front Current Feedback Exceeded |
B2220 | Window Driver Rear Current Feedback Exceeded |
{mospagebreak}
B2221 | Window Passenger Front Current Feedback Exceeded |
B2222 | Window Passenger Rear Current Feedback Exceeded |
B2223 | Mirror Driver Drive Circuit Failure |
B2224 | Mirror Passenger Drive Circuit Failure |
B2225 | Front Crash Sensor Mount Fault |
B2226 | Front Crash Sensor Internal Fault |
B2227 | Front Crash Sensor Driver Communications Fault |
B2228 | Air Bag Driver Circuit Short to Ground – Loop #2 |
B2229 | Air Bag Passenger Circuit Short to Ground – Loop #2 |
B2230 | Air Bag Driver Circuit Short to Battery – Loop #2 |
B2231 | Air Bag Passenger Circuit Short to Battery – Loop #2 |
B2232 | Air Bag Driver Circuit Open – Loop #2 |
B2233 | Air Bag passenger Circuit Open – Loop #2 |
B2234 | Air Bag Driver Inflator Circuit Resistance Low on Squib – Loop #2 |
B2235 | Air Bag Passenger Inflator Circuit |
B2236 | Weak or Defected Electric Vehicle Battery Module Fault |
B2237 | Vehicle Signal indicating Park While VSS Present |
B2238 | Power Cable For Power Sliding Door Broken |
B2239 | Rear Cargo Door Set Switch Stuck (Short to Ground) |
B2240 | Rear Cargo Door Reset Switch Stuck (Short to Ground) |
B2241 | Rear Cargo Door Lock Circuit Short to Ground |
B2242 | Rear Cargo Door Unlock Circuit Open |
B2243 | Driver Rear Door Ajar Circuit Open |
B2244 | Driver Sliding Door Ajar Circuit Short to GND |
B2245 | Passenger Rear Door Ajar Circuit Open |
B2246 | Passenger Sliding Door Ajar Circuit Short to GND |
B2247 | EV Battery Pack Temperature Fault |
B2248 | Heated Windshield Relay Coil Circuit Failure |
B2249 | Head Lamp Relay Coil Short to Battery |
B2250 | All Doors Unlock Relay Circuit Failure |
B2251 | Parklamp Output Relay Driver Circuit Failure |
B2252 | Parklamp Output Relay Dirver Short to Battery |
{mospagebreak}
B2300 | Seat Driver Memory Position Error |
B2301 | Seat Passenger Memory Position Error |
B2302 | Seat Headrest Feedback Potentiometer Circuit Failure |
B2303 | Seat Headrest Feedback Potentiometer Circuit Open |
B2304 | Seat Headrest Feedback Potentiometer Circuit Short to Battery |
B2305 | Seat Headrest Feedback Potentiometer Circuit Short to Ground |
B2306 | Seat Headrest Motor Stalled |
B2310 | Mirror Driver Memory Position Error |
B2311 | Mirror Passenger Memory Position Error |
B2312 | Mirror Passenger Horizontal Feedback Potentiometer Circuit Failure |
B2313 | Mirror Passenger Horizontal Feedback Potentiometer Circuit Open |
B2314 | Mirror Passenger Horizontal Feedback Potentiometer Circuit Short to Battery |
B2315 | Mirror Passenger Horizontal Feedback Potentiometer Circuit Short to Ground |
B2316 | Mirror Passenger Vertical Feedback Potentiometer Circuit Failure |
B2317 | Mirror Passenger Vertical Feedback Potentiometer Circuit Open |
B2318 | Mirror Passenger Vertical Feedback Potentiometer Circuit Short to Battery |
B2319 | Mirror Passenger Vertical Feedback Potentiometer Circuit Short to Ground |
B2320 | Mirror Driver Horizontal Feedback Potentiometer Circuit Failure |
B2321 | Mirror Driver Horizontal Feedback Potentiometer Circuit Open |
B2322 | Mirror Driver Horizontal Feedback Potentiometer Circuit Short to Battery |
B2323 | Mirror Driver Horizontal Feedback Potentiometer Circuit Short to Ground |
B2324 | Mirror Driver Vertical Feedback Potentiometer Circuit Failure |
B2325 | Mirror Driver Vertical Feedback Potentiometer Circuit Open |
B2326 | Mirror Driver Vertical Feedback Potentiometer Circuit Short to Battery |
B2327 | Mirror Driver Vertical Feedback Potentiometer Circuit Short to Ground |
B2328 | Column Reach Feedback Potentiometer Circuit Failure |
B2329 | Column Reach Feedback Potentiometer Circuit Open |
B2330 | Column Reach Feedback Potentiometer Circuit Short to Battery |
B2331 | Column Reach Feedback Potentiometer Circuit Short to Ground |
B2332 | Column Tilt Feedback Potentiometer Circuit Failure |
B2333 | Column Tilt Feedback Potentiometer Circuit Open |
B2334 | Column Tilt Feedback Potentiometer Circuit Short to Battery |
B2335 | Column Tilt Feedback Potentiometer Circuit Short to Ground |
B2336 | Mirror Switch Assembly Circuit Failure |
B2337 | Mirror Switch Assembly Circuit Open |
B2338 | Mirror Switch Assembly Circuit Short to Battery |
B2339 | Mirror Switch Assembly Circuit Short to Ground |
B2340 | Column Reach Motor Stalled |
{mospagebreak}
B2341 | Column Tilt Motor Stalled |
B2342 | Seat Switch Reference Voltage Positive Common Open Circuit |
B2343 | Seat Switch Reference Voltage Positive Common Supply Low Voltage |
B2344 | Seat Switch Reference Voltage Positive Common Supply Voltage Fault |
B2345 | Seat Switch Reference Voltage Negative Common Open Circuit |
B2346 | Mirror Switch Reference Voltage Positive Common Open Circuit |
B2347 | Mirror Switch Reference Voltage Positive Common Supply Low Voltage |
B2348 | Mirror Switch Reference Voltage Positive Common Supply Voltage Fault |
B2349 | Mirror Switch Reference Voltage Negative Common Open Circuit |
B2350 | Steering Column Switch Circuit Short to Battery |
B2351 | Steering Column Switch Circuit Failure |
B2352 | Driver Memory Power Switch Indicator Circuit Short to Battery |
B2353 | Driver Mirror Power Driver Circuit Short Ground |
B2354 | Driver Mirror Horizontal / Vertical Feedback Potentiometer Circuit Open |
B2355 | Passenger Mirror Horizontal / Vertical Feedback Potentiometer Circuit Open |
B2357 | Driver Window Down Current Sense Low Circuit Failure |
B2362 | Remote Open/Close signal Circuit Short to Ground |
B2363 | Optical Sensor System Failure |
B2364 | Fuel Filler Door Circuit Open |
B2365 | B-pillar Power Sliding Door Open/Close Switch Input Ckt Short to Gnd |
B2366 | IP Power Sliding Door Open/Close switch Ckt Short to Gnd |
B2367 | Power Sliding Door Override Switch Input Ckt Short to Gnd |
B2368 | Steering Column Switch Circuit Out of Range |
B2369 | Chime OUTPUT Request Ckt Short to Ground |
B2373 | LED #1 Circuit Short to Battery |
B2374 | Power Sliding Detent (Latch) Circuit Failure |
B2380 | Heater Coolant Temp sensor circuit Short to GND |
{mospagebreak}
B2381 | Heater Coolant Temp sensor circuit Open |
B2384 | Audio Reverse Aid Mute Input Ckt Failure |
B2385 | Audio Navigation Mute Input Ckt Failure |
B2401 | Audio Tape Deck Mechanism Fault |
B2402 | Audio CD/DJ Thermal Shutdown Fault |
B2403 | Audio CD/DJ Internal Fault |
B2404 | Audio Steering Wheel Switch Circuit Fault |
B2405 | Audio Single-Disc CD Player Thermal Shutdown Fault |
B2406 | Audio Single-Disc CD Player Internal Fault |
B2416 | Climate Control Recirculation Actuator Out of Limits |
B2425 | Remote Keyless Entry Out of Synchronization |
B2426 | Passenger Solar Radiation Sensor Circuit Open |
B2427 | Passenger Solar Radiation Sensor Circuit Short to Ground |
B2428 | A/C Post Heater Sensor #2 Circuit Failure |
B2429 | A/C Post Heater Sensor #2 Circuit Short to Ground |
B2431 | Transponder Programming Failed |
B2432 | Drivers Seat Belt Buckle Switch Circuit Open |
B2433 | Drivers Seat Belt Buckle Switch Circuit Short to Battery |
B2434 | Drivers Seat Belt Buckle Switch Circuit Short to Ground |
B2435 | Drivers Seat Belt Buckle Switch Resistance out of Range |
B2436 | Passengers Seat Belt Buckle Switch Circuit Open |
B2437 | Passengers Seat Belt Buckle Switch Circuit Short to Battery |
B2438 | Passengers Seat Belt Buckle Switch Circuit Short to Ground |
B2439 | Passengers Seat Belt Buckle Switch Resistance out of Range |
B2440 | Passenger Side, Side crash sensor mount fault |
B2441 | Driver Side, Side crash sensor mount fault |
B2442 | Intrusion Sensor Fault |
B2443 | Powertrain Performance Mode Switch Circuit failure |
B2444 | Driver Side Crash Sensor Internal Fault |
B2445 | Passenger Side Crash Sensor Internal Fault |
B2446 | RESCU/VEMS Input Circuit Open |
B2447 | RESCU/VEMS Input Circuit Short to Battery |
B2448 | RESCU/VEMS Input Circuit Short to Ground |
B2449 | Aux Heater Glow Plug Circuit Short to Ground |
B2450 | Aux Heater Glow Plug Circuit Open |
B2451 | Aux Heater Fuel Pump Circuit Short to Ground |
B2452 | Aux Heater Fuel Pump Circuit Open |
B2453 | Aux Heater Blower Fan Circuit Short to Ground |
B2454 | Aux Heater Blower Fan Circuit Open |
B2455 | Aux Heater Blower Faulted |
B2456 | Aux Heater Coolant Sensor Circuit Short to Ground |
B2457 | Aux Heater Coolant Sensor Circuit Open |
B2458 | Aux Heater Overheat Sensor Circuit Short to Ground |
B2459 | Aux Heater Overheat Sensor Circuit Open |
B2460 | Aux Heater Flame Sensor Circuit Short to Ground |
{mospagebreak}
B2461 | Aux Heater Flame Sensor Circuit Open |
B2462 | Aux Heater Flame Out Fault |
B2463 | Aux Heater Overheat Fault |
B2464 | Aux Heater Start Time Exceeded |
B2465 | Aux Heater Start Counter Overrun/System Locked (same as below ?) |
B2466 | Aux Heater Overheat Counter Overrun/System Locked |
B2467 | Aux Heater Cool Down Time Exceeded (may be con to a453-5 ) |
B2468 | Aux Heater Coolant Pump Circuit Short to Ground |
B2469 | Aux Heater Coolant Pump Circuit Open |
B2470 | Interior Fan Control Circuit Short to Ground |
B2471 | Interior Fan Control Circuit Open |
B2472 | Fog Lamp Switch Failure |
B2473 | Passenger Door Disarm Switch ckt Short to Ground |
B2474 | Passenger Door Lock Switch Circuit Shorted to Ground |
B2475 | Passenger Door Unlock Switch Circuit Shorted to Ground |
B2476 | RADIO PRESENT SWITCH Ckt Failure |
B2477 | Module Configuration Failure |
B2478 | ANTI THEFT INPUT SIGNAL SHORT TO GROUND |
B2479 | BRAKE PARK SWITCH CIRCUIT SHORT TO GROUND |
B2480 | LF CORNER LAMP OUTPUT Ckt Short to Battery |
B2481 | Convertible Top Up/Down switch Fault |
B2482 | RF CORNER LAMP OUTPUT Ckt Short to Battery |
B2483 | Enable Signal Open Circuit |
B2484 | Disable Signal Short to Ground |
B2485 | LF SIDE REPEATER LAMP OUTPUT Ckt Short to Battery |
B2487 | RF SIDE REPEATER LAMP OUTPUT Ckt Short to Battery |
B2489 | UNDERHOOD LAMP OUTPUT CIRCUIT Failure |
B2490 | UNDERHOOD LAMP OUTPUT CIRCUIT Short to Battery |
B2491 | RF PARK LAMP OUTPUT CIRCUIT Short to Battery |
B2492 | Already Programmed (Test Mode DTC Only !!!) |
B2493 | LF PARK LAMP OUTPUT CIRCUIT Short to Battery |
B2494 | ANTI THEFT HORN OUTPUT CIRCUIT Short to Batt |
B2495 | ANTI THEFT HORN OUTPUT CIRCUIT Failure |
B2496 | ANTI THEFT HORN OUTPUT CIRCUIT Short to Gnd |
B2499 | COURTESY LAMP OUTPUT Failure |
B2500 | COURTESY LAMP OUTPUT Ckt Short to Battery |
{mospagebreak}
B2501 | LF LAMP LOW BEAM CIRCUIT Failure |
B2502 | LF LAMP LOW BEAM CIRCUIT Short to Battery |
B2503 | RF LAMP LOW BEAM CIRCUIT Failure |
B2504 | RF LAMP LOW BEAM CIRCUIT Short to Battery |
B2505 | LF LAMP HIGH BEAM CIRCUIT Failure |
B2506 | LF LAMP HIGH BEAM CIRCUIT Short to Battery |
B2507 | RF LAMP HIGH BEAM CIRCUIT Failure |
B2508 | RF LAMP HIGH BEAM CIRCUIT Short to Battery |
B2509 | Rear Fog Lamp Switch Circuit Failure |
B2510 | Main Blower Motor Relay Circuit Short to Battery |
B2511 | Horn Output Relay Circuit Short to Battery |
B2512 | Front Fog Lamp Relay Ckt Short to Battery |
B2513 | Blower (Fan) Circuit Failure |
B2514 | Blower (Fan) Circuit Short to Vbatt |
B2515 | Heater Blower Relay Circuit Failure |
B2516 | Blower Control Circuit Failure |
B2517 | Emergency Power Off System Faulted |
B2518 | Compressor Overtemp Fault |
B2519 | High Mount Stop Lamp Circuit Failure |
B2520 | High Mount Stop Lamp Circuit Short to Battery |
B2523 | License Lamp Circuit Failure |
B2524 | License Lamp Circuit Short to Battery |
B2525 | Left Rear Backup Lamp Circuit Failure |
B2526 | Left Rear Backup Lamp Circuit Short to Battery |
B2527 | Left Rear Stop lamp Circuit Failure |
B2528 | Left Rear Stop lamp Circuit Short to Battery |
B2529 | Left Rear Turn Lamp Circuit Failure |
B2530 | Left Rear Turn Lamp Circuit Short to Battery |
B2531 | Right Rear Backup Lamp Circuit Failure |
B2532 | Right Rear Backup Lamp Circuit Short to Battery |
B2533 | Right Rear Stop lamp Circuit Failure |
B2534 | Right Rear Stop lamp Circuit Short to Battery |
B2535 | Right Rear Turn Lamp Circuit Failure |
B2536 | Right Rear Turn Lamp Circuit Short to Battery |
B2539 | Aux A/C Mode Position Reference Circuit Short to Ground |
B2540 | Aux A/C Mode Position Reference Circuit Short to Battery |
{mospagebreak}
B2543 | Aux A/C Control Switch Reference Circuit Short to Ground |
B2544 | Aux A/C Control Switch Reference Circuit Short to Battery |
B2545 | System Power Relay Circuit Short to Battery |
B2546 | System Power Relay Circuit Failure |
B2550 | LAMP DOME OUTPUT Circuit Short to Ground |
B2553 | Disable Signal Output Circuit Short to Battery |
B2554 | LAMP DOME OUTPUT Circuit Failure |
B2555 | LAMP DOME OUTPUT Circuit Short to Battery |
B2556 | Enable Signal Circuit Short to Battery |
B2557 | Left Power Sliding Door Open/Close Output Circuit Short to Battery |
B2558 | Right Power Sliding Door Open/Close Output Circuit Short to Battery |
B2559 | Aux A/C Blower Motor Relay Circuit Short to Battery |
B2560 | Aux A/C Blower Motor Relay Circuit Short to Ground |
B2561 | Aux A/C Blower Speed 1 Circuit Failure |
B2562 | Aux A/C Blower Speed 1 Circuit Short to Ground |
B2563 | Aux A/C Blower Speed 2 Circuit Failure |
B2564 | Aux A/C Blower Speed 2 Circuit Short to Ground |
B2565 | Right Tail Lamp Circuit Failure |
B2566 | Right Tail Lamp Circuit Short to Ground |
B2567 | Reverse Mirror Output Circuit Failure |
B2568 | Reverse Mirror Output Circuit Short to Ground |
B2569 | Liftgate Disarm Switch Circuit Short to Ground |
B2570 | Right Lamp Outage Signal Circuit Short to Ground |
B2571 | Left Lamp Outage Signal Circuit Short to Ground |
B2580 | Aux Blower Sense Switch Circuit Failure |
{mospagebreak}
B2581 | Passenger Seat Occupant Detection Circuit Short To Ground |
B2582 | Passenger Seat Occupant Detection Circuit Open |
B2583 | Child Seat Detection Circuit Short to Ground |
B2584 | Child Seat Detection Circuit Open |
B2585 | Anti Theft Input Signal Circuit Short To Battery |
B2586 | Headlamp Mode Select Circuit Failure |
B2587 | Passenger Seat Occupant Detection Circuit Short To Battery |
B2588 | Child Seat Detection Circuit Short To Battery |
B2589 | Unexpected Door Reversal During Close |
B2590 | Vehicle Park/Speed Signal Circuit Failure |
B2591 | Detent Signal Missing During Unlatch |
B2592 | PSD Not Fully Closed (Module Commanded Successfully) |
B2593 | Power Sliding Door Opened During Module Close Command |
B2594 | No Movement Detected After an Unlatch During Power Open |
B2595 | Anti Theft Input Signal Circuit Failure |
B2596 | Headlamp Aim Output Relay Circuit Short To Battery |
B2597 | Headlamp Aim Output Relay Circuit Failure |
B2598 | Headlamp Relay Circuit Failure |
B2599 | Tailgate Release Open Circuit |
B2600 | Double Locking Door Motor Frozen |
B2601 | No Latch Signal Sensed on Closing and Door Reversed |
B2602 | Missing Latch Signal During Power Sliding Door Unlatch |
B2603 | PSD Not Fully Closed During Self-Test |
B2604 | Power Sliding Door On/Off Switch Open Circuit |
B2605 | Disable Signal Open Circuit |
B2606 | A/C Temperature Sensor Out of Range |
