If you are working on your car and turn the ignition on while your airbags are unplugged, the Airbag SRS Light will turn on and keep flashing. Infiniti dealer will charge you close to $100 to clear that light. Please follow the steps to successfuly clear the SRS light.
Basically it needs to be done 3 times to enter the Diagnostic Mode, then the fourth time keep the key in the ON-position to stay in Diagnostic Mode. Stay here for a few more seconds. Then the fifth time you turn the key, it will clear the diagnostic mode and get the car back into User Mode. Here is the exact wording of this from the service manual:
HOW TO ERASE SELF-DIAGNOSIS RESULTS
After a malfunction is repaired, turn ignition switch OFF for at least one second, then back ON. Diagnosis mode returns to the User mode. At that time, the self-diagnostic result is cleared.
Auto-Talk does not guarantee and will not be responsible for the damages occured by using this guide.
