Please follow the instructions step-by-step in order for the remote programming to work. These instructions are useful for 2003 2004 Honda Element. This procedure clears the transmitter codes and creates new ones, so you must program all remotes at the same time, even if one or more is already working.
  • Enter the car and close all doors.
  • Each of the following steps must be completed within five seconds of completing the previous step. If you take longer or make a mistake, start the entire procedure over again.
  • Insert the key into the ignition, and hold one remote in your left hand. Whenever the instructions say to press the LOCK button, you should press the lock button on the remote for about a second and then release it.
  • Perform each of the following three steps in order, then repeat all three steps two more times, for a total of three times each:
           1. Turn the ignition switch to the ON position, marked II.
           2. Press the LOCK button.
           3. Turn the ignition switch to the Off  position, marked I.
  • Do this three times!
  • Next, turn the ignition switch to the ON position (II) for a fourth time.
  • Press the LOCK button again. The door locks should now make a cycling sound, indicating that the system has entered Programming Mode.
  • Press the LOCK button one more time to program this remote. If you have other remotes to program, press the LOCK button on each one in turn. The door locks should make the cycling sound after you press LOCK on each remote. You may program up to three remotes, and they must all be programmed within ten seconds of each other.
  • Turn the ignition off and remove the key. The remotes are now programmed and may be tested.
  • If you've got a trunk/hatch release, hold the button for this function for a few seconds.
