Chrysler LLC has been hinting at the upcoming arrival of their own version of the ZF-built eight speed automatic for the 2012 model year. The company has finally let the cat out of the bag by releasing official details on their new transmission. First debuting underneath the 2012 Chrysler 300 and Dodge Charger, the 845RE is, at its core, is a ZF but Chrysler has applied a few key tricks so they can claim it as their own.
At first, the only engine matched with the eight speed will be the 3.6 liter Pentastar V6 in the 300 and Charger. Both rear wheel and all wheel drive models will receive the transmission. Because of it, the big-bodied, full size sedans are now in the 30 mpg club with a EPA-rated 31 mpg on the highway. With the previous, Chrysler-built five speed auto, the LX cars could only muster 27 mpg on the freeway. City driving will also net more miles per gallon with a EPA-rated 19 mpg. That’s up five percent from the 2011 models. And with a lower working rate, the eight speed allows both the 300 and Charger to reduce their emissions by 11 percent.
A new final drive ratio has been added to work with the eight speed: 2.65:1 for rear drive and 3.07:1 for the all wheel drive trims. Acceleration is down slightly as 60 mph comes up in 7.2 seconds with a sport shift mode that allows for faster, redline gear changes. No structural changes were needed to fit the 845RE and a simple, 3 kilogram weight gain was seen compared to the older five speed unit.
Read Chrysler’s full press release below.
The first eight-speed automatic transmission in a domestically produced automobile will mark its debut on both the Chrysler 300 and Dodge Charger for 2012.
The new eight-speed automatic, introduced and licensed through ZF and often found on high-end luxury cars including Audi, Bentley, BMW, Range Rover and Rolls Royce, will be available on selected models of the Chrysler 300 and Dodge Charger. Initially, the transmission will be mated exclusively to the award-winning 3.6-liter V6 Pentastar engine that was introduced last year.
The result is a four mile-per-gallon increase that pushes highway fuel economy to an EPA-rated 31 mpg for the 2012 Chrysler 300 and 2012 Dodge Charger – up from 27 mpg highway over last year’s model.
The transmission efficiency and wide ratio spread also provide the best possible fuel economy in city traffic. Fuel economy for both models is 19 mpg on the EPA city cycle – an increase of five percent over last year’s five speed automatic. With eight speeds, driving at a lower rpm in both city and highway environments also effectively helps reduce emissions by nearly 11 percent on both vehicles.
For those living in inclement weather climates or wanting the proven traction of four wheels, all-wheel-drive variants of the transmission also will be available on both models for 2012. Designed as a modular transmission, the 845RE allows for the addition of Chrysler’s all-wheel drive system. This all-wheel drive is engaged only when needed, requires no driver input and helps improve fuel economy by only engaging the front-drive wheels when there is excessive wheel spin.
Compact and lightweight, the new transmission required no structural changes to either vehicle and despite the addition of more gears, the transmission actually weighs just 3kg more than the outgoing five speed automatic transmission.
Coupled to the new rear-wheel-drive automatic is a differential with final drive ratio of 2.65:1. The transmission efficiency and gear ratio spread enable spending more time at lower engine rpm and the use of numerically low axle ratios further improve highway fuel economy. All-wheel-drive models are equipped with a 3.07;1 final drive ratio.
Fully electronic and aided with software that provides an adaptive shifting strategy, the 845RE has been designed to provide optimal shifting characteristics consistent with the Chrysler and Dodge brands. Adaptive shifting takes into account a number of variables including engine torque gradients, kick down, longitudinal and lateral acceleration, hill detection, friction detection and downshift detection in determining shift patterns. Additional parameters include vehicle speed control, electronic stability control activation and high temperatures that can affect transmission shifting.
The addition of more gear ratios in the transmission helps reduce the gaps normally associated with upshifting and downshifting. Both vehicles benefit from nearly imperceptible gear changes due in part to very evenly spaced gear steps between each gear ratio. The gear steps also are very small providing quicker acceleration and smoother shifts.
High efforts in shifting also have been eliminated with gear selection controlled by a shift-by-wire system. The position selected by the driver (P, R, N, D) is transmitted electronically with no mechanical linkage from the shifter to the outside of the transmission. Elimination of this linkage removes any shift effort from the driver’s gear selection. Shift-by-wire also allows improved calibration and smoothness of garage and parking lot shifts.
All shifts, whether single, double or multiple are performed as a direct result of the pedal position. Downshifts are made with very short response times and lead directly to the requested gear. Multiple upshifts can be decoupled temporarily if the torque request changes during the upshift. This helps eliminate the shift searching of the transmission.
During more spirited driving conditions, sporty, quick shifts are possible as a result of multiple parameters either through a Sport shift mode that requires simple driver input. At the rear of the shifter is a gate that allows for down- and up-shifting by the driver. Once the vehicle is in the Sport mode, the driver can use either the console-mounted shifter or a pair of paddle controls located on the steering wheel.
Once the Sport mode is selected, shift times are quicker and engine rpm is allowed to increase for a more performance- oriented acceleration and higher shift dynamics.
Acceleration times for the Dodge Charger and Chrysler 300 for 0-to-60 mph are 7.2 seconds.
Internally, the 845RE transmission features four gear sets and five shift elements (multi-disc clutches and brakes) inside the transmission. With fewer open shift elements, drag losses due to multiple parts rotating relative to one another, are reduced.
Additionally, lower viscosity transmission fluid is used resulting in improved transmission efficiency and fuel economy improvements especially during cold environments or vehicle start-up. The 845RE also is “fill for life” not requiring oil changes during normal driving conditions.
The all-new automatic transmission will initially be purchased through ZF. Production by Chrysler at its Kokomo transmission facility under license by the German-based company is slated following introduction.
